J
jndietz
The Way It Moves
Should I normalize all of my waveforms to a certain volume before I sent them into the mixing process?
Both previous answers are right on the mark. Check for yourself. Let's see... 28 thread with normalize in the title.This subject has been discussed thoroughly a few times, so use the search function.![]()
Ummmm...Should I normalize all of my waveforms to a certain volume before I sent them into the mixing process?
It's nothing more than raising the overall level of the file until its highest peak reaches a specified point, often 0 dBFS or just slightly under....i still don't know what "normalizing" theorhetically does...
There's two types of "normalization". The first one, called "peak normalization" is the kind that XLR described. It's really nothing more than a volume level conrtol that sets the volume not by amount of gain like a normal volume control, but rather by seeting the highest volume level for the loudest peak in the wave.i still don't know what "normalizing" theorhetically does,
That's how all the modern pop mixes are done.
Duh... Somehow I missed that part... Still, even then I think I am only slightly exaggerating... I know that limiting the drum submix at least is becoming increasingly routineI don't think even those boneheads do that before the mix.
Eh, that's not a threatSsshhhhh...don't give them any ideas!Otherwise we'll have to unleash a Kurzweil beast on you....
Jackpot..... perfectly understood bro, thanks, so with the first one it sets the volume via the loudest peak of the track to i'll assume make sure it doesn't rise above that high-pointThere's two types of "normalization". The first one, called "peak normalization" is the kind that XLR described. It's really nothing more than a volume level conrtol that sets the volume not by amount of gain like a normal volume control, but rather by seeting the highest volume level for the loudest peak in the wave.
The second kind is called "RMS normalization". This is also a fancy volume control, but rather than setting the volume by peak volume, it's setting it by the average (RMS) volume level. These normalizers usually include brick wall compression at the top of the scale to avoid clipping.
Neither one should be used before mixing because there is no reason why every track should be at the same volume levels - either peak or average. If that were the case, there'd be no need for mixing, would there?And raising the volume without reason is just taking away headroom that could be better used downstream.
G.
Good point.I know that limiting the drum submix at least is becoming increasingly routine![]()
Kinda early to be tugging on Santa's pantleg, isn't it? Just increases the amount of time you have to be a good boyEh, that's not a threatIt's more like a prayer... Oh man... the more I read about it, the more excited I get. Talk about pure synthesis nirvana!
Keep up the good work and keep trying new stuffsinistah said:i'm taking babysteps to a better mixdown each time i log on...thanks guys!
Oh man, Santa's real afterall? And here I'm trying to work the woman.Kinda early to be tugging on Santa's pantleg, isn't it? Just increases the amount of time you have to be a good boy![]()
You could do what one of my buddies did this summer...Oh man, Santa's real afterall? And here I'm trying to work the woman.Barking up the wrong tree I guess
To each his own re terminology, as audio is so fragmented that way...."RMS normalization". This is also a fancy volume control, but rather than setting the volume by peak volume, it's setting it by the average (RMS) volume level. These normalizers usually include brick wall compression at the top of the scale to avoid clipping.
