snow lizard
Dedicated Slacker
How bad does that non-linearity get?
I didn't think dB's were linear to begin with so I would guess that it's pretty bad.
I'm just guessing.
sl
What Im seeing is that if I have everything at 0VU then the converter is also sitting at what it considers zero. Some of them at -18, some at -12, some at -15. They all seem to be pretty good about that...Even the cheapies are pulling that to .01 or so db, nothing horrible out of whack. but from there, the math doesnt always work, if -18dbfs is 0VU Im seeing +19 or +20 to get zero dbfs to read on the daw's meters, frightfully sometimes even if the converter's lights are showing an over it still might be 0.8 dbfs down on the daw.
Pipeline, thanks a bunch for the excellent and detailed reply. Very informative - not to mention very timely, as (to some people's dismay) I am just finishing up on a web app re introductory metering and gain sturcture, and I'll add a bit of a blurb nodding to this information.If we are saying 0 is -18, think of how much gain over zero that is! Thats asking great classic devices to REALLY be operating in a range they werent exactly optimized for.
True. What I was referring to was the break in the normally linear (though offset) 1:1 relationship between dBu and dBFS (i.e. adding one dBu means adding one dBFS), as well as what I assume (wrongly?) to be a probably non-linear response in the converter circuitry that causes the effect that pipeline described (the "Pipeline Effect"?snow lizard said:I didn't think dB's were linear to begin with
Glen,You still are implying that, even with a safety factor, boosting digital gain to get the most bit usage without clipping is the way to go. We have been trying to explain why that is not the case.
Maybe once your rep strength moves off of 666, you'll see the differences in the devil in the details![]()
G.
To quote from a Protools reference guide:
7. Adjust the output level of your sound source (instrument, mixer or preamp)
Monitor the track's meter levels in Protools to ensure that you get the highest possible signal without clipping. My italics.
A hot mix is a loud mix.
Tim,Glen,
So I'm not just implying it now. I'm still implying it, am I? Then why did I say in my initial post (the part you edited out of your quote) "theoretically anyway, for minimum converter noise"?
Why did you edit out my caveat which limits what I say and qualifies it, and then criticize me for allegedly not having said it?
What you still apparently don't understand, Tim, is that there is an A in ADC. Every converter includes an analog input stage. It's the analog level at that gain point (either at the ADC input gain or, if one is not available, at the output gain of the preceeding device) that we're referring to. Just because one uses the term "preamp" doesn't automatically mean a seperate microphone preamp.I was speaking where converter noise is the limiting factor. Not the analog preamp noise or indeed anything which appears earlier in the signal chain.
Even that is a misunderstanding of what I was trying to explain. I think I should give up, because it's just not getting through the translation barrier, you just don't understand.OF COURSE boosting gain only to add system noise to the track will limit the potential dynamic range of the recording.
Now you're just contradicting yourself even more, Tim. First you're getting on our cases for bringing up anything upstream of the D part of the ADC, because the OP and the thread were specifically referring to the digital levels only, and now you're getting on my case for "assuming" that you're talking about digital gain levels.Interesting that you imply I said to turn up converter gain. I said nothing about where in the chain to increase gain. It could have been by getting the talent to come closer to the mic! (Interestingly that's how Les Paul recounts how he cut preamp noise in some of his early recordings)
One last time, I was referring to boosting the digital gain, which serves only to raise the converted noise floor. No it noes not add noise, but it does make the existing noise louder.But even if gain is increased inappropriately so as to reduce overall headroom (and I regard it as inappropriate, like everybody else who understands the issue) it's only a reduction in POTENTIAL. If the recording did not clip, nothing was lost.
Better would be to remove the word "clip" altogether, as it referrs to the digital side of the equation, and the idea of boosting the post-converter digital gain is what's bogus. Best would be to remove the "hot as you can" reference altogether and instead state that one should simply follow good gain structure procedure. "As hot as you can" and "as hot as you should" are two different things.Thinking about what I said, yes I could have said it better. Better would be, "get your track above system noise, but dont clip".
No it's not.So long as both criteria are satisfied it's good advice.
The entire professional audio engineering community has a problem with it. C'mon, Tim, you've been around this forum long enough to have seen the conversation several times over. The PT manual isn't the only one to say that; there are a *lot* of manuals out there for various hardware and software that says much the same thing.Again, I'm happy with the Protools manual advice. "highest possible signal without clipping" If you have a problem with that, so be it.
One could say a few things, Tim. First, that it was a joke that you are apparently still wound too tight to get. Loosen up, budAs for your parting rep points comment, really, what can one say, Glen?
Exactly my position, too, sl. Looking at it from the peak perspective is looking at it ass-backwards, IMHO. of course one does not want to clip their peaks, but to select a specific level for peak values totally ignores the actual crest factor of the program material.snow lizard said:I'm surprised the article was talking in peak levels rather than RMS. If a preamp is equipped with a VU meter, it's going to have slow ballistics, so you're not going to pick up most of the transients. Digital meters are fast. Targeting -6 peak dBFS as a generalization could be dangerous given the differences in transient content of, say, a clean acoustic guitar vs. a distorted electric guitar vs. a drum kit vs. a sine wave, et cetera.
I have NEVER heard a preamp which gets cleaner as it approaches the end of its range. I have also never heard one that stays the same.
I think it's 70% (A) and 30% (B), and that it's just not him, but a whole generation of home recordists.Reading through, it seems that he either (A) doesn't understand or (B) doesn't want to understand the whole concept.
The good news is that the Volume Wars are not going to last forever; they are simply the polyester leisure suit and big hair of audio production fashon. The bad news is I have no idea of what production version of narrow ties and hair mousse is going to replace them next.masteringhouse said:Isn't it odd though that while we MEs preach about not recording hot, keeping peaks below 0 dBFS, and not clipping, we make CDs that are hot, peak as close to 0dBFS as possible, and clip converters for certain types of music?
The irony that I find in this whole topic is that it's a fairly regularly heard complaint on this board and those like it that the "pros" keep the important "secrets" to themselves. One of the most important not so secret "secrets" that most of the more expereinced folks here constantly drill is the importance of getting the tracking right. A major part of getting the tracking right is understanding the importance of good gain structure in the tracking chain to get the best performance out of whatever gear one uses. Yet when the topic *does* come up and is discussed, those that complain about not being let in on the "secrets" don't get when one is being handed to them for free on a silver modem.G.
1. The line going into the interface (i.e. the output from the previous upstream device.
2. The input gain (if adjustable) on the interface. If not adjustable, how that may or may not affect what you do in #1.
3. The digital output or driver level control of the digital signal coming out of the interface and into the computer.
4. The track recording level fader in the multitrack software.
