O
		omtayslick
I have been using a garden variety dynamic (EV 257A) to mic kick drum.  Am I missing something significant by not having a dedicated kick mic such as a Beta 52, AKG 112, etc.?
			Yes................
A dynamic mic meant for vox/guitar just isn't going to capture the low-end detail of a good sounding kick. You really need a larger diaphragm.
I personally prefer the EV RE20, but the D112 is quite popular. For years I used a Beyerdynamic TGX-50 with great results, but they don't make those anymore.
Are you sure you don't have that backwards? The beta 52 is the one with no mids and is excessivly boomy and clicky. The D112 is the one that you have to take out a ton of 400hz to make it sound more "metal".I too recommend the Beta 52, find the D112 is a bit limited if you want any variety (with the scooped mids) but great for metal.
I'm one of the guys that makes those samples...where do you think they come from? I also do a lot of metal. I use the samples when the drummer is:To be quite frank... if metal is the sound you are after... forget getting a good kick sound. You could use a Nady $3 dynamic in that case then use sample replacement. Like it or not, that is more often than not how it is done in metal.
A. Playing too fast to get the kick drum to 'speak'
B. Is too inconsistant dynamically
C. Doesn't have the right head/drum combination to get the right sound
D. The band wants that drum machine sound (normally because of A, B, or C)
D112 would be the best bet.Thanks for the replies guys. BTW, music styles are rock, country/rock and blues.
