guitarman09
Soon I will be framing a room inside my basement, which has cement floors and walls. I plan on framing the 2x4s about 16" away from the walls; to the next ceiling joist. I have a bunch of polystyrene sheathing boards, and i figure it would do the room good acoustically if i line the walls with these insulation boards. The cement walls will be a factor because i am not drywalling the room yet(lack of finances, time,...) and will most likely only insulate between the wall studs for now.
I was wondering if anyone knew anything about the sound absorbing qualities of the insulation boards i have, and if they will make a difference in room acoustics if they're covering the cement walls.
Also, what is a good but cheap way to build the floor? I was thinking of laying the 2x4s, insulating with whatever R-value fluffy fiberglass insulation fits, laying plywood, and then a carpet. Will this be fine or will i have problems with sound reflections off the floor?
any suggestions are valued.
Thanks.
Thanks.
