Steve Henningsgard
I've noticed, doing more and more in-the-box mixing, it can be really hard to just listen to the damn mix, trusting your ears instead of your eyes. Having read as many articles/forum posts as I have about the subject, it would appear I'm not alone in having this obstacle! Having no control surface other than the one inside the DAW makes it even harder, as you can't really adjust much with your eyes closed.
I came across my solution quite by accident: during a long mix session, I got tired of twisting virtual knobs (head outta the gutters man), so I just went to the beginning of the project and hit "play", turned off the screen and just laid back in my comfy chair, eyes closed. I started drifting to sleep, and noticed that certain elements of the mix made it hard for me to fall completely asleep. So I turned the monitor back on, adjusted those elements, started the song over and turned the monitor off again. I repeated this process a good 4-5 times until I eventually did fall just about totally to sleep. I drove home, came back in the morning and started up the mix, and compared it to where I had started the previous day when I first turned my monitor off. So much smoother/better! I've tried this with a couple subsequent mixes and they've turned out to be some of my best work yet by far.
Anybody else tried the "sleep" method? I'm absolutely certain I'm not the first to try this with success, but I hadn't heard it suggested anywhere else so I figured I'd post it!
