PhilGood
Juice box hero
I am so close to finishing this U47 clone I can taste it.
But I've run into this huge problem. Since I'm using an EF14 instead of a VF14 for the tube I have to supply filament voltage separately. I decided to make a similar PS to what I used on my Ela M clone, which works beautifully, but when I plug the mic in, the filament voltage drops to less than a volt. I've tried a power supply from an MXL V69, since I used the same socket pinout. That power supply with power the filament at +6 volts or so, but the B+ voltage drops to 25v when it should be 100.
An ideas what might be wrong? I think it may have to do with the ground in the PS but I'm not sure.
Anyone have proper schematics for the real modification? I've been very very close to the original U47 schematic and haven't deviated at all except for trying to supply filament seperately.
I can probably draw up what I've done so far and post it if that helps. Here's the PS. I can get the mic scematic, but just imagine I've removed the R3 and R4 resistors (29ohm and 1780ohm respectively) and gone directly from the power supply with ground and 6.3v. It reads over 10.6v unloaded.
Maybe I'm not doing the cathode bias right.
P
P
