engine joe
In case any of you would like to use a manual testing method or compare Centrance LTU results with manual testing results, here is a manual testing method:
- Set your sequencer to software monitoring.
- Start an empty project without any plugins running.
- Setup a stereo track, set it to input monitoring.
- Connect your left output to the right input straight away (if possible, use a single cable, so no outboard gear is blurring up the results).
- Connect something sending out a signal to the left input. A single cable with a plain jack might do. You need to record something with a clear attack, so touching the tip of the jack wih something such as a screwdriver would most likely be a good idea. But virtually anything will do, you just need a clearly identifyable attack.
- Record a bit on that stereo track while "clicking".
- Compare the offset of the recorded clicks in the left and the right channels (the right channel will be the delayed "software monitored" one). This offset will be your total system latency.
- If your time schedule allows for it, please perform the test at different soundcard buffer sizes and samplerates.
If any of you compare the results from this testing method with the results from Centrance LTU, please post them here. I have used this testing method on a M-Audio 1010LT in the past and here are the results:
- Abit VA-10, AMD 1.2 ghz, 768 mb ddr, 2 x 80 gb wd hdds
- Win XP
- Reaper 1.812
- M-Audio 1010lt, driver 5.10.00.0052
- Results:
44.1 kHz, 256 samples buffer: 842 samples = 019 ms
44.1 kHz, 128 samples buffer: 456 samples = 010 ms
44.1 kHz, 64 samples buffer: 265 samples = 006 ms
48 khz, 256 samples buffer: 841 samples = 018 ms
48 khz, 128 samples buffer: 457 samples = 010 ms
48 khz, 64 samples buffer: 264 samples = 006 ms
96 kHz, 256 samples buffer: 840 samples = 009 ms
96 kHz, 128 samples buffer: 455 samples = 005 ms
96 kHz, 64 samples buffer: 264 samples = 002 ms
I will be comparing the results from this test method with the results from Centrance LTU as soon as I get some time at home. I'm on the road for another month.
Is anyone interested in a test method for track misalignment? How about MIDI latency? All this latency stuff is pretty messy and I'm guessing that most folks don't realize how it affects their recordings.
- Win XP
- Reaper 1.812
- Results:
