Blue Jinn
Rider of the ARPocalypse
I picked one of these up on the cheap, w/o a PSU. So I haven't been able to test it out, but did some research about it and found a schematic on GS and a discussion of mods to it on GDiy. I also went and bought a used V76t which uses the same PSU (and AFAIK is the same mic on the inside.)
So, first, if anyone has used one, opinions? And, looking at the schematic, it has a parallel triode section, a fairly high B+ and a weird coupling capacitor set between the tube and transformer. Also, there's a lot of presumably RFI filtering on the output.
The coupling capacitor is really baffling,: a small value high voltage, in parallel with a lower voltage (considering the B+ of 200v) higher value electrolytic. As soon as I get the V76t I'm going to try it out, but have in mind replacing the coupling cap with something more conventional, 1 or 2 uF high voltage cap, and perhaps strip out the RFI section and use that part of the PCB to add pattern switching (after swapping capsules). Once I commence that I'll post a DIY thread, but thought I'd start here to get people's opinions overall of the stock mic.
