A Reel Person
It's Too Funky in Here!!!
The Tascam 244 has a S/N Ratio of 90dB under optimal conditions.
At 3%THD at 20hz with the DBX on and tracking well. Without DBX, it's 58db.The Tascam 244 has a S/N Ratio of 90dB under optimal conditions.
Normally, I do everything in 24 bit. I suppose if you get good levels, 16 bit will be fine. The digital noise floor ( the only thing that bit depth affects), will be lower than the noise floor of your tracks, so no harm done.
All processing in the daw will be done at 32 bit float, so it dosen't affect that.
The only time it will make a difference is if you process a track and save the file with the processing. But there isn't much reason to do that if you are just mixing.
Now, where 24 bit would make a difference is during processing. All processing will create some sort of noise or artifacts. (this happens with analog too) This stuff all happens around the noise floor. If you use 24 bit, those artifacts end up so far down that they don't matter ever. Also, once the audio is converted to 16 bit during mastering, all the artifacts get thrown away with those last 8 bits.
Always mix down to 24 bit, then convert to 16 bit during mastering.
Are you still talking about dumping files recorded on the 244 to computer?
What 4-track cassette multitracker are you using?
The noise floor of 16-bit digital will be well below the 54dB S/N ratio of the 234 without dbx.
Are you dubbing mixes to the computer as a stereo track, or are you dubbing 4 discrete tracks to the DAW?
If you're mixing, are you using the 234's onboard stereo mixer or an external mixer?
Just curious.
Thanks
I think you got it now. Good luck.4 discrete tracks. Thought about using some sort of mixing board for analog sound, but I do very little processing so I don't think it would make a difference, and I can take advantage of digital convenience. Doesn't sound like it will make any difference whatsoever whether 16 or 24 bit. But just cause I may as well, I well save the rest in 24 and leave the 16 bit.
Thanks Farview and friends. Feel free to state any considerate opinions for what I am doing if anyone feels so inclined. THanks!
