Kingofpain678
Returned from the dead
You know your monitors are good when they make your anus bleed.
I only have a slight bloody discharge.... about 5" worth.
... with a 1" tweeter
Is that Prince KC ^ Nice beaufont.
absolutely worthless with treated boxers...you'll need some auralex ball traps
That's all well and fine but I'm having trouble figuring out how to nail my balls to the wall.
you not married yet?
they know dude, they know......
I've been through my entire CD collection in search of something that sounds ok, Strokes, Interpol, AC/DC, Pink Floyd, Crowded House, Pixies etc...all types of stuff and everthing just sounds so boxed in and muddy.
Guys thanks for all the replies. Regarding connectivity I'm using RCA (phono on back of guitarport) to TRS 1/4" balanced on the back of the monitors. Currently the speakers are placed directly on the table, admittingly this is not ideal (they do have a rubber pad on the bottom which helps a liitle) but then so where my old speakers.
By the way, I'm all for getting the best out of the KRK's before I make my mind up.
Thanks guys.
Thanks guys.
Isnt Guitar Port just a front end ? So if you are trying to use it as a stand alone sound card you may be facing the usual difficulties line 6 throws at you - like the need for Pod Farm to be running and this may be processing your output in some way. Can you check your internal routing ? Can you run a signal straight from your computer ?
KRK RP5G2 Rokit G2 Powered 2-Way Active Monitor
The KRK RP5G2 Rokit G2 Powered Studio Monitor takes this KRK design to new heights. All of the great stuff that Rokit's have been known for including front-firing bass port, soft-domed tweeter, glass aramid composite yellow cone are still there, but the G2 Rokit's feature refined voicing and a new curved baffle that looks great, reduces diffraction and provides even better monitoring accuracy. Tweak: Surprising bass, and even more surprising, its not tubby like a lot of 5's. Great starter monitors.
Can you just try to bypass the Guitarport anyway ?
1/8 inch to RCA cable with some RCA to 1/4 inch mono plugs if needed.
