John W. LeBlanc
Strange Leaf said:Analog mixing is it. More expensive, but totally worth it.
It's more expensive depending on the context.
Since the sound is getting into the DAW through the Delta series AD converters, there's really not much point in expecting anything better than a Delta 1010 (or Delta 1010-LT) to handle the DA conversion to do analog mixing.
The next step is choosing a mixing console that, at minimum, doesn't suck any worse that the Delta series DA converters. That puts things squarely in Mackie territory.
Given the situation, and the fact that he's using SONAR as his DAW and the Delta ADs on the front end, digital summing in SONAR will easily beat out any DA/analog console setup he's likely to be able to afford.
For the work I do, I record one or two tracks at a time. The AD is a Lucid clocked to the GENx6-96 and it goes straight into Samplitude 7.0 Pro. I mix in Samplitude using a control surface. Major label quality? I don't think so, but that's not the sort of work I'm doing.
I find the summing engine in Samplitude to be more than acceptable for my work, and superior to SONAR 2.x, which I beta tested and compared to Samplitude.
For me to do the mixing in analog and equal or better the sound of the summing engine in Samplitude, I'd have to purchase a number of DAs at least as good as the Lucids and a quality console. I don't find it necessary to expend that sort of jack.
I am happy enough with the sound of Samplitude's summing engine to not even bother mixing anything through my Yamaha 02R via the lightpipes anymore.
In a way it seems rather silly to rationally compare sitting at an analog console pushing faders and twisting knobs, to digital mixing when, to achieve a sound in analog exceeding the quality of digital summing in one of the top DAW software packages, requires a quantum leap in equipment cost.
Just another opinion.
John LeBlanc
Houston, TX
