Disease8
I want to make a long story simple. erm...
Well I got a pro 40 top replace my alesis io26 (I think wise choice except loosing 8 input channels).
The main reason I swapped was to get the far superior software and have the ability to route any thing to anything. The io26 did not have this and to play back recordings to musicians on different output pairs you would have to actually UNPLUG and plug back into that pair. Yep you could only have the DAV output out of one pair at a TIME.
So I have used the Fiocusrite to reord a band and some other bits and bobs like lead rap vocal... etc..
I think everything going into it and coming out is lacking in over all quality and high end detail... I also had a problem with latency which I contacted Focusrite about and they have been very helpfull (unlike Alesis).
So we werre trouble sdhooting stuff to find which device was causing the latencyI think I worked out it is caused by my cheap firewire pcmcia card even though its definitely TI chipset and so is the card controller in my laptop.
I plugged in my Delta M-Audio card from my desktop and the difference was amazing the m-audio delta pci card sounded so much clearer. So
Do I have a faulty Focusrite or is it the pcmcia card? Can pcmcia effect the sound like that?
I would have thought not .. But then the Focusrite should not sound THAT much worse than the M-Audio Delta?!?!?!?!?
Check the recording I have done on the Focusrite:
