Anytime you look for one box to do it all you will be making compromises.
TRK,
This is true to an extent, although it is becoming less and less the case as better equipment is being developed more cheaply all the time.
If you want a better shot at professional results just use the recorder and effects on a portastudio or DAW.
If that is your mindset, you are probably better off not going with a portastudio, or an all-in-one solution. You would probably be better off getting a Mackie, Tascam, Radar, or some other recording medium, and adding the outboard to your liking. People who purchase all-in-one units have generally made a trade off. They have traded portability for flexibility. In some cases, this lack of flexibility is purposefully built in by the manufacturers. Roland is one of the worst offenders where this is concerned. They puposefully make things proprietary, so you have to come to them for solutions. A perfect example of this is the lack of compatibility with other CD burners on the VS units. They want you to buy their burner.
That being said, the Roland units are noted for having excellent quality mixers, and excellent quality internal efx. You'd better like them, you're not going to be using anyone elses plug-ins.
Whenever possible use external pres, DAC's, processors and yes even an analog mixer for mixing. I would rather mix on a better board even with the additional DAC if I get more headroom, seperation and depth in return.
I'm not at all against using better outboard gear. I'm for it all the way. However, with these machines, you do have limitations. If you want to use an external mixer, don't buy one of these machines. It is not practical, if not impossible, to mix externally on one of these machines. You don't have analog outputs for all the channels.
It might be possible in some type of incredibly inane way. The only way I can think of would be to somehow dump all the tracks into a computer, then acquire all the extra output gear it would take to acquire the analog outputs to route the tracks to your analog mixer. Then you would have to master down to two tracks and go back to a digital medium if you were wanting to have a CD master.
Don't get me wrong. I'm not disagreeing with you in principle. I agree that going from the digital to analog domain and then back again is desirable if you have a decent analog board and you can benefit from it's headroom, eq, or effects. It's just really not in any way a practical option on these units.
TRK, let me ask you this.
I am very much a student of recording technology, I find it fascinating, and there is a lot of things I don't understand as well as I would like too. This headroom issue is one area where I will have to plead ignorance.
Let's take a hypothetical situation. Lets say you did have analog outputs for each track on a VS unit. Would you be gaining anything in the way of headroom by going out to the analog mixer? Wouldn't you still be constrained by the limitations of the digital track mixer on the VS? Is their any way to gain head room after you've gone through the digital mixer on the VS?
Regards,
Taylor
