That could be it, even if I doubt it.Porter said:I'm thinking that the Creative is acting as a 'pre-amp' to some extent
What I`m baffled about here is.... Why run the track information thru the valves again when all you have to do is use the "bounce to track(s)" option?
moskus said:I'm starting to think that either:
A) There is something strange with the Microsoft driver
or
B) Vice's computer is haunted
But as long as the "Recording Fader" is set to max, they should be the same, right? The faders don't boost the signal, they only reduce it...James Argo said:That's the answer...
moskus said:But as long as the "Recording Fader" is set to max, they should be the same, right? The faders don't boost the signal, they only reduce it...
This actually reminds me of a discussion I had in the Sound Card forum a year or so ago. In that disucssion, I took a position that was something along the lines of your recording volume is entirely controlled by your external equipment, and that the faders in the Windows Mixer and Sonar only effect playback levels.moskus said:But as long as the "Recording Fader" is set to max, they should be the same, right? The faders don't boost the signal, they only reduce it...
dachay2tnr said:...BTW, Vice, why you would re-record the mixdown in the first place excapes me. I would have simply exported it as a wave file, or bounced to tracks. Re-recording doesn't make a lot of sense to me. (But then, neither does use of the Console View )
First of all, the "definition" of Line In is a input with no amplification (-10 dBU). If it would, then the Live!-card would certainly "destroy" the sound. Tell them that.dachay2tnr said:Now I know the Live card has a preamp in the mic in jack, but I don't know about the Line in jack. I would have guessed it didn't, but this discussion and my previous one lead me to believe that maybe it does.
If it does, moskus, then the fader could increase the recording level. Which might also explain Vice's situation.
Moskus, actually I agree with you (can't believe I said that). However, I can't explain that several people argued vehemently with me that they controlled their recording volume by using the Windows Mixer.moskus said:First of all, the "definition" of Line In is a input with no amplification (-10 dBU). If it would, then the Live!-card would certainly "destroy" the sound. Tell them that.
As much as I've read about the SB Live! I've never seen something about having a preamp on the Line In...
And even if Creative should have included this on the card (which is see as very unlikely, preamps cost money!), then it would not matter on the bounce/mixdown-action as Sonar don't run the sound through the soundcard in either of these actions.
This leads me to believe that it's more like a "driver-thing", and that bounce/mixdown somehow is affected by how the driver handle the sound...
vicevursa said:
I'm thinking it's more of the haunted scenario. I have never had good luck with computers. I always end up with some unexplainable problem that no one can seem to help me with. I thought maybe with my new DAW I was good to go. I mean it works and everything is fine. It just doesn't make any sense. All I wanted to do is find some sort of consistency, some base line to which I could reference my recordings. With the last five projects I have mixed, nothing has come out the same. I was hoping this one would be the one. I'm still searching...
Vice
