Porter said:
What are the settings on the Aux Busses... any way they might be 'amplifying' the sound?
ie, when you bounce clips, does the signal pass through the Aux Busses? I know they will be with a Mix Down.
Porter
When I do the bounce to tracks I leave everything checked. So, everything is included.
mixsit -
Here's my recording process:
1) I do everything in midi first.
2) Then I convert my midi to audio. I ended up with 13 tracks of audio.
3) Then I began to mix these tracks together, finding levels adding effects and panning.
4) Then when I think I am about done, I solo all the tracks I want to use and play them together and do some more adjusting to make sure they don't cause any clipping.
5) Now, I set up a stereo audio track, arm it for recording. and hit record.
That is how the mixdown track was created.
Now, the bounce to track method:
Since steps 1 thru 4 were already complete. I simply went to the edit menu -> Bounce to Tracks. Ensured all the checks were present and hit OK.
The result was two different waveforms.
I have no plugs on the v-mains and I used a reverb on Aux 1 and a different reverb on Aux 2.
I can't honestly say why I did things this way. I guess I figured I could save myself a step with the Bounce to tracks method. I didn't know it was going to get me all confused and unsure about what I am doing...
I hope you understand how I did this mixsit...
Vice
