Roozter
Has anyone tried using ATR tape on a Tascam 80-8? Is it even able to be used on one?
it would probably function alright, but it's not ideal. RGMI 911 or 468 would be better options for new tape.
Not ideal for the transport? Or for the heads? or sonically? How so?
yes it is different. I guess i did not asked the question correctly. So what i meant was, if there is higher noise floor or any other effect if you are operating +9 tape on a +6 biases machine. I understand that for sure you won't get any of the extra benefits, but vs. 456 on the same deck is there anything bad about it ? (other than no compression due to lack of saturation)
I wanna step in real quick...
ATR tape runs at *any* operating level. Its formulation allows it to be run on most decks without realigning. Mike Spitz said that most of his customers record on ATR at +6. And it sounds great at +6. Or even +3.
Just trying to dispel a popular misconception.
Reviving this thread. Our summer recording project is fast approaching and I've yet to decide where I'm going to go in terms of new tape. RMGI vs ATR.
I realize sm911 is what I would need. But I am also reading various sources saying ATR 1/2" on an 80-8 would be no problem, in fact, I would probably get a much better final product.
Apparently ATR is superior to any tape on the market today, literally it is, and it can be used on just about any tape machine if set up correctly. The issue seems to be that ATR cant sell anything because this +9 hoodoo is casting quite a shadow over it, and causing people to doubt if the extra price is worth the hassle of setting it up.
My 80-8 should be set to +4.5 (as a starting point) to use ATR. Where the problems come in, and this has been mentioned, will be full and complete erasure. So if someone can figure out, or knows how to fix that issue, I think Ill be switching over to ATR to try it out.
I may even try to make some type of guide for getting ATR to work sufficiently on my 80-8 and mastering machine, so that maybe others would feel comfortable using both ATR and RMGI.
Set up @ +3 level after you have set your bias. It should work just fine with no erasure problems.
Have you been using ATR frequently, and on what machine? I cant seem to find enough credible sources to get an overall picture of how ATR is functioning on consumer and prosumer decks.
Like you said, at the very least people are having erasure issues, and some have remedied this, but can still hear faint sounds from the leftovers.
My plan, if the ATR works on the 80-8, is to use it for all my machines, stockpiling 1/2" and 1/4". Then I have to find myself a suitable blank cassette to buy in bulk.
