Higher output tape (i.e. +9, +11, +1,035.3) does
not make for more "bitchin' tape compression".
I know many know this already, so I'm preaching to the choir, but there is also a common misunderstanding.
+3, +6, +9 etc. refers to the level at which that particular tape becomes saturated and presents 3% harmonic distortion. The harmonic distortion artifacts are what seem to be referred to as "warmth", "tape compression" or "phat tape mojo", etc.
So that means a higher output tape needs a hotter signal to reach those "results". No problem, right? Just SLAM IT!!
Um, not exactly...
That means your tape deck audio amps need to be able to handle pushing those levels without clipping themselves (which doesn't sound as "nice" as the tape distortion). This isn't usually a problem, but is something to consider.
Then there is the bias issue. Many tape deck's bias amplification can't meet the levels needed to properly bias super high output tape. You might think this is isolated, but I know for fact even the Tascam 58 and MS-16 can't without a simple mod to a cap on the amp cards. Regardless, maybe you like the sound of high output tape that is under-biased. That's fine. Each to his/her own, I just think its important for operators to understand what they are doing so it can be replicated...harnessed...
used. Some people purposely underbias certain tracks containing certain types of source material...kick drum is one such example...setting bias while tracking and monitoring off the play head to get a certain "bite" on the attack which is coming from [cue dramatic music] distortion as a result of under biasing the tape! But some like the sound, so try it! Experiment, but seek to know WHY you get the results you like so you can apply them elsewhere...and have control of your equipment. The flip-side of the bias issue is the bias amps also provide erasure. Your tape deck's ability to effectively erase previously recorded material on the tape while recording may be compromised if your levels are hotter to tape than the erase function can wipe. You gotta experiment. This was an issue on the early Ampex MM-1000 24-track machines...in order to get the proper erasure, the bias level had to be increased and it actually heated the early erase heads up and caused them to crack.
This is not necessarily related to the tape type, but shows you there are other limits at play when we are asking our machines to do stuff for which they weren't necessarily intended.
Crosstalk...you're going to deal with it on a narrow format machine if you have screaming levels. This isn't an issue with many types of source material (screaming thrash for instance...crosstalk? Who cares...) Just be aware.
Then let's remember to throw noise reduction into the mix...if you are using dbx n/r for instance you aren't likely to be throwing high levels at your tape anyway unless you are trying to get pumping and other mis-tracking artifacts in your audio. So there isn't any point in getting super high output tape if you are setting the machine up to factory spec because you are using noise reduction (i.e. factory spec says set 0VU to 250nWb/m and track with levels averaging 0VU when using n/r), then you aren't taking advantage of the high level the tape will handle before distorting. And that's okay. If your machine will bias the tape (or under/over bias to your liking if that's your bag), then use whatever tape you want...you don't have to push it into saturation. Tape saturation is just one of the fun mechanisms of analog tape recording. I'm just saying if the spec calls for +6 tape and you are setting the machine up to spec, and you can get +6 tape for $X
less than some super high output offering, why waste the money?
Super high output tape wasn't developed so it could eat insanely hot levels and sound phat...it was developed so the tape could handle hotter signal that put what got tracked to tape further away from the noise floor of the tape..."quieter" recordings in terms of noise. The market was asking for lower noise, and the mechanisms that create noise on tape are fixed, but the tape formulation and what the oxide will handle before saturation is reached is what could be messed with...and they did...and that gave is +3 tape, and then +6 tape, and then +9 tape, and then the even higher MOL standard of the ATR tape.
Am I right guys?
So if you went with the intention of the manufacturers, your reasoning for getting ATR tape would be so you had more headroom to track
before the tape distorted while also creating more distance from the noise floor of the tape. This is more important on source material that has greater dynamic range. This would not be your favorite thrash band...softer jazz, classical...material with more quiet and space in the program material...space that would reveal the noise floor of the tape. You can either use noise reduction are "reduce the noise" by increasing the level of program material to the tape as the tape will allow.
SO...
This is the place I always come to...and it seems
backwards...but if you are REALLY wanting that bitchin' phat tape mojo, then you are better to go with a
*lower* output tape...I have 499 (a +9 formulation) for my Ampex MM-1000. It'll bias it, and get it to saturation and erase it fine, but its definitely not what the machine was
designed for. I have some Scotch 206 (a +3 tape) for it as well. I've never used the 206, but I'll be able to have more leeway with how I saturate/use the tape without challenging amplifier output/bias issues/erasure performance, because the point at which the tape saturates is easier to reach.
Food for thought.
Nothing against ATR or any super high output tape at all. I just feel it is important to understand the intent of the different tape types, to have a grasp of the potential caveats, and to be able to harness the
advantages of analog tape; the world of options that open up when you can control your results knowing how to use biasing and SOL/MOL standards. Know your machine...assess what result you want and why...then set it up for that or
experiment.
Have fun.
