Re-tox_stl
They sure are pretty though
Pretty...perhaps. Fully functional, not so much.They sure are pretty though
Overkill is so much fun!!
I doubt that crossflow heat sink is store bought.
I meant what looks to me like 5 stacks of sheet metal in this photo.
ummm, I think it comes with the territory. Anyone considering building a home studio has GOT to be insane in the first place.fitZ, that stuff is absolutely insane.
Naahhhhhh, your handiwork looks great Myraid, and at least your studio is comin right along...vs mine..which seems to be a lifes work.:laughingsSo...after being shamed by fitZ' work yet again, here's some pics of where I'm at right now
Yea,kinda, but not from my own choosing. There just isn't any work(for what I do.)here. I moved here a few years back and found work at a couple of local cabinet shops..one as a CAD detailer, and when that one closed, got another job as a cabinet maker , but at half the wages I was making where I came from. Then the economy crashed... and STAYED crashed..at least where I am. But I keep busy, and do get some side jobs, as my shop is pretty complete.This all begs the question...are you retired?
Because I would never get that done.
Well, I learned a lot of stuff when I worked at a Store Fixture manufacturer. But tell ya what. You can learn a lot on Youtube now. Maybe not everything, but a lot. And there's tricks to everything. If I don't know how to do something, I do what my dad has always told me. THINK about it..and LOOK at it. Like welding. I've got a project for my car that requires brazing a custom made adapter for my power steering pump.Let alone have the know how.
This is what it looked like 5 minutes ago.
Nah, it doesn't bother me. I'll clean it up soon enough. I kind of know where everything is right now. Sort of. It's controlled chaos.Temporary shelving.
Already ahead of you. I did that this past weekend when I got all the crap in my racks.And yes, tap lights on the underside of the racks in the back are a wise idea.
I have an oak template made for one leg right now. I could make another, no big deal. But, I can only angle the racks so much before they go off the carpet. Since I'm a bit OCD and anal retentive, that won't fly with my brain. Besides, I play guitar a lot and I've learned over the years that angles in desks make for headstock dings on my nice guitars. So I'll probably pass on the angles...at least for now.But I still say you should build your table legs, so you can angle those racks inward for easy access to front controls and not rolling from side to side.
What kind of cable did you use? What kind of connectors? Brands? Where did you get them?Yup. Oil is hella combustible, and hitting oily steel with a torch either flares up a big flame in your face or outright BLOW'D UP.
As for soldering, I've been doing TONS of XLR fittings on mic cables. It's not hard at all. And if you buy your cable on a bulk 100ft or 250ft spool, and order bulk of your XLR connectors, you can set up a bit of an assembly line and make everything run like clockwork. If you wanna do cost cutting, order bulk, set up a TV by your table, and listen to your shows as you cut, strip, crimp and solder away.
I wanted six 40ft mic cables. Store bought with good quality products, that was around 300 bucks. After shopping around, I did it home made, around 87 bucks.
Speaking of soldering..well, maybe not soldering but BRAZING...As for soldering, I've been doing TONS of XLR fittings on mic cables
