G
gregg.mckiernan
Hey all,
So I have been curiously toiling away with recording techniques since I was 15 or so, but at 19, those 4 years of experience have taught me a lot about USB recording interfaces (such as those by M-audio or Presonus) but my pop just recently purchased a 16 track recorder/USB interface by ZOOM and it came with Steinbergs Cubase LE 5. Up until this point I have used Cool Edit Pro 2.0, which is an effective program, but I have recently sought to expand my knowledge into this much more complex software.
To give you the logistics of my rig, the ZOOM interface has a sample rate of 44.1kHz, but I am sure with some tinkering that could be improved. I will be running up to 8 tracks simultaneously through the interface into Cubase, but when it comes to the software I am completely out of the water.
What I aim to accomplish, is to have 8 tracks taken straight from the ZOOM interface, through the mixer in Cubase, and to be able to apply real time playback out of my PA system (This is another rut I have fallen into, in regards to using my laptop as the mixer for raw audio, how then would I produce this audio through my PA system. I will read up on the ZOOM interface as to whether or not its mixer is active while not in Record, but rather Interface mode (when in Record it draws power externally, when you turn it off, it immediately feeds to interface mode using USB power.)
Another alternative I have just brought to my own attention is the availability of having a TAPCO 12 track analog mixer, which is what I currently have hooked up to my PA. I will post images of the gear, but keep in mind that my knowledge of Steinbergs Cubase LE 5 is much more limited than that of my analog sound production. I look forward to open discussion on the topic, and appreciate any insight that you may have!
Thanks,
Gregg
Thanks,
Gregg
