Ricklh said:
I'm looking at these two units and leaning towards the new Fostex (8 tracks instead of 4). Here's my question regarding the Zoom MRS-4: it has 2 line inputs and 2 aux. inputs, none that are specifically labeled "mic inputs" and no built-in mic either. To use a mic with this unit, I assume I'd have to use a mic pre-amp such as an ART Tube MP before plugging into the Zoom? Any Zoom users/owners here that can answer that?
Also, the Zoom has 4 tracks with 8 virtual tracks on each of the four. The Fostex has 8 tracks, no virtual. Would one be more useful than the other?
Thanks.
Rick,
I own
the Zoom MRS-4, great little machine.
I will try to answer your questions as simply as possible.
1. The line inputs double as mic inputs, you just adjust the levels accordingly. It does not have to have a sererate mic pre.
2. The two aux. inputs cannot be recorded, they are strickly for listening, and have a set volume level, this means whatever you plug into them must have its own volume control.
What this means is that the MRS-4 only has two recordable inputs. You will almost asuradly need a stand alone mixer.
3. The Zoom has no real guitar proccesing, I use a Pod.
It does have chorus and delay, but no distortion, or amp modeling. The Fostex does have a guitar proccesor, if I'm not mistaken.
4. With the Zoom you will have to do more bouncing down, than you will with the Fostex.
The Zoom fits my need fine, because I have a guitar proccesor, and a mixer that makes up for the Zooms inputs.
Seems like the Fostex would be a better choice, flexibility wise, got to say I do dig my Zoom though.
You will most likely be better off with the Fostex. I think it also comes with 128 mb card, as apposed to the Zooms 32mb card. This is something to consider, as memory cards aren't cheap.
I have a couple of songs that I did on my Zoom MRS-4 that your welcome to listen to.
Songs; 1 Steeley Jam
2. Long Ago 3
http://www.nowhereradio.com/gt/singles
Good luck
GT
