Yamaha fs1r - very mint
  • Thread starter Thread starter fiddler2007
F
fiddler2007
Member
Yamaha fs1r, sparsely used, superb condition non-smoking home studio, first owner since 2001;
Original packaging present, all original manuals, 2 CDs, manual copy in Dutch-speak too.
Included is Emagic' s adapted sound-diver editor, it still seems to work on windows 10.
Latest firmware 1.2, 220-240 v Euro plug version, Internal battery just renewed, factory reset.
Shipping from the Netherlands, shippingcosts depend on location, price 2400 Euro.
NOTE: it's a 220-240 volts 50/60hz version, so you'll need a voltage converter maybe.
Payment tip: pay internationally via Wise to a bank through a linked Credit card seems quite safe.
There is a general demo video on Youtube:
It's still for sale, and i found some useful tips on a tech site NOT in the manual, in case of problems (this one hasn't LoL).
Yamaha FS1R fixing tips not in the manual.
V1.20 OS EPROM is the latest.
Factory Reset. Reset: hold both Util and Enter at startup
Yamaha FS1R V1.20 OS EPROM. Release Notes
Fixes numerous system bugs, voice allocation issues, file compatibility issues and user interface issues.
Improves DX7 patch import. Improves MIDI Sysex compatibility. Improves overall MIDI functionality.
Check OS EPROM version
Your current OS EPROM version is displayed when you boot up your Yamaha FS1R while holding the [PLAY] and [MUTE/SOLO] buttons
INITIALIZING various:
The FS1R Initialize function includes five sub-modes: Perform, Voice, Fseq, Sys, and FactSet. Factory Set
initialization restores all FS1R data to the initial factory settings including all current and Internal
voices. System Initialize restores all system setup parameters to their default settings.
Initializes the performance edit buffer.
Perform:
Voice
Initializes the current voice edit buffer.
Initializes all or individual internal Fseqs (I01 - I06) if internal Fseq memory is allocated.
The Fseq memory is cleared after Fseq execution, allowing reception of bulk Fseq data from an external source (i.e. another FS1R).
Sys
Initializes all system setup data.
FactSet
Initializes all FS1R data to the initial factory settings.
Select a Data Type to Initialize
1.
Use the CURSOR [ ] and [ ] buttons or the CURSOR knob to select the desired data type to be initialized.
Press [ENTER]
2.
Press the [ENTER] button to go to the confirmation display for the selected data type. If Fseq is selected, use
the VALUE [ ] and [ ] buttons to select either all Fseqs, or an individual Fseq from I01 through I06.
Press [ENTER] to Initialize
3.
Press the [ENTER] button to begin actual initialization (or [EXIT] to abort). ìExecutingî will appear on the
display while the data is being initialized, then the display will return to the Initialize menu.
Exit When Done
4.
Press the [EXIT] button to return to the UTILITY mode menu, or [PLAY] to return directly to the PLAY mode
when done.
FAINT DISPLAY:
You can adjust change display contrast:
go to SYS press enter
use cursor to go to OTHER
press enter
LCD contrast should now be on the screen
press enter
use value buttons to change contrast
