XLR - Hot, Cold, and Ground?
  • Thread starter Thread starter sjaguar13
sjaguar13
On an XLR cable, what is the prong on the left hot, the middle top one ground, and the right one cold?
Pin 1: Ground
Pin 2: Hot (+)
Pin 3: Cold (-)
If you are looking at the male end it reads from left to right.
Top left pin: 1
Top right pin: 2
Bottom pin: 3
If you are looking at the female end it reads from right to left
Top right pin: 1
Top left pin: 2
Bottom pin: 3
TRS correspondent:
Tip: Hot (+)
Ring: Cold (-)
Sleeve: Ground
Some older gear and some european gear may be different, but this is now pretty much standard.
Tom Cram
dbx Senior Technical Support
(801) 568-7530
tcram@dbxpro.com
"I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it."
-Thomas Jefferson-
On all XLRs, there are numbers next to each pin (on the front and the back of the plug or jack). Pin 1 is ground, Pin 2 is the positive signal, and Pin 3 is the negative signal. The negative signal is a mirror image of the positive signal, but with the polarity reversed.
Tom is of course right. Unfortunately, not all companies follow the standard for pins two and three, and they are reversed (Pin 2 cold, pin three hot). The good news is that this almost never matters, because the human ear can not hear the difference.
Light
"Cowards can never be moral."
M.K. Gandhi
