A
AbZu
Strange problem with the following setup showing the wrong notes on the screen although playing the right note.
Windows XP Pro +SP1
Creamware Luna II sound card
Yamaha CS1x keyboard
As a sample of the problem: using a program with an on-screen piano keyboard, in this case Voyetra's TeachMe Piano. Playing middle C on the yamaha keyboard is displayed as B, although the sound played is correct (C). If C sharp is played, it is displayed as middle C. I checked the MIDI mapping with an app called MIDI monitor and sure enough playing middle C is interpreted as B4 corresponding to the note displayed. Playing C sharp is interpreted as C5 (middle C) corresponding to the note displayed.
In the Audio tab of Sounds and Audio Devices Properties of Xp, I tried all the options available for the default device for MIDI music playback, which are: CreamWare MIDI In/Out 1 and Microsoft GS Wavetable SW synth, with and without the "use only default devices" option.
Program's settings are:
MIDI input device > CreamWare MIDI In/Out 1
MIDI output device > CreamWare MIDI In/Out 1
Patch Map > General MIDI (no other option available)
Sounds to me (no pun intended) that the error maybe between the Luna II soundcard and XP's MIDI mapper. ¿¿¿ Any ideas ???
Windows XP Pro +SP1
