Wiring xlr wall plates
  • Thread starter Thread starter Phyl
P
Phyl
Guest
I have a wall plate in my tracking room that will house 12 XLR connectors. 12 channel snake wire runs from this wall plate to another wall plate in the control room. From there I'll build short snakes to connect the mic lines to my mixer.
The wall plate XLR connectors have metal bodies and a lug that could used to solder a wire to in case you wanted to ground the connector body.
Should I tie all these lugs together in each wall plate, use the master ground wire in my snake to connect the two plates, then run a wire to the mixer ground? This would connect all the connector bodies to the mixer ground.
Or maybe the connector bodies in each wall plate should float.
Float each ground! Don't connect the panel to ground. You are inviting all sorts of trouble if you allow all the grounds to connect there.
I've posted the same question elsewhere and this seems to be the consensus - thanks guys.
