Wiring a TRS to XLR Cable
  • Thread starter Thread starter Phyl
P
Phyl
Guest
I need to make some cables in order to run my pre-amp outputs to a patch bay. The cables will have XLR at one end and TRS at the other.
I know I need to tie the braid to the connector case at both ends.
Is there a standard convention for which XLR pins should connect to the tip and ring of the TRS plug?
i hope i'm correct;µ
the TIP of the trs --> pin 2 of XLR
the Ring of the trs--> pin 3 of XLR
the sleeve of trs ---> pin 1 of XLR
and...i got an additional question about patchbays:
do we always have to use TRS cables on a patchbay ?
i guess so, but i'm a patchbay newbie, and damn, its hard shit to understand..
i hope this helped,
cheers
earworm
Your XLR/TRS wiring info is what I've seen elsewhere on the web, just wanted some independant verification - thanks.
As far your question - I have both unbalanced and balanced devices hooked up to my patch bay and use only TRS patch cables. No problems yet.
Get a copy of The Sound Reinforcement Handbook by Gary Davis, about $30. It's got the answer to every kind of question about cables (no optical, though).
