Monte,
Here is something posted onmidman's website in the FAQ section. The problem is with win2k, you can only pass audio thru the USB. You can not use it as a control surface. This is the main reason I bought it. It even has a template for Cubase.
From
the EZbus FAQ section of our Website:
What drivers does EZbus come with?
On the PC:
The EZbus uses either a WDM (Windows Driver Model) driver, which is
supported by Windows ME (Millennium Edition) and Windows XP, or the EZbus
ASIO driver. The EZbus uses an MME driver which is supported by Windows 98
Second Edition and Windows 2000. All of these drivers provide two channels
of full-duplex audio via USB.
Windows Millennium and Windows XP users have the ability to send/receive
MIDI information via the EZbus/computer USB port. Other operating system
(Win 98 SE, Win 2000) users will need an additional MIDI interface installed
and configured within the chosen application to send/receive MIDI data to
and from EZbus and the chosen application.
Anyway, last night I installed the upgrade but have not had a chance to load the EZBus yet. I did encounter another problem though after the install. I was able to play cd's & mp3's ok, but when I loaded Cubase and played one of the sample songs, it would drop out every second or two. I tried messing with the buffer settings on my Delta 1010 control panel but got the same results.
Any hints to this new problems would be appreciated.
