SPANISH_ARMADA
I built a recording booth, but have run into bit of a problem.I dont know what to do for the window. Should i do the double window "V" technique?, glass or plexi?, or should i just use a single thick glass?.
specs of my booth.
awkard dimensions/ avoided 90 degree angles
built frame with 2x4
will fill walls with sand
and instead of using drywall, i will be using mdf. Very dense, heavy wood.
then cover booth with a rubbery, cork material mat, then foam on top of that.
any help would be greatly appreciated. Thanks.
specs of my booth.
