I am going out my mic into the compressor out the compressor into my mixer. When i talk in the mic mic the lights on the compressor blinks but i get no sound into my mixer. Can I get some help thanks.
i am using a dynamic mic. The output gain is on -9. The plug going out the mic into the compressor is xlr male to female, but the plug going out the compressor to my mixer is xlr to 1/4. "Are you going inline or inserted? " I have no idea what that is.
What kind of board are you using? You need to look on the back of the board for a set of jacks labelled 'Insert', there should be one right above or below the place where the mics XLR cable plugs in. The inserts are basically a send and return on one TRS 1/4" phone jack.
Bruce was being a bit facetious here, but right on the mark!
You need to "pre-amplify" the microphone before you consider using a compressor.
Try running the mic straight into the mixer, then the mixers output into the compressor's inputs, then the compressor's outputs into your recording device. That should clear up any volume problems.
If that's a question then the answer is yes. But if you've run your mic through a pre and a compressor, I don't see a whole lot of need for sending the signal through a mixer at that point. Why not just send it straight to your recorder, whatever it is?
