T
tvolhein
Tom Volhein
Wouldn't it be better to get a good tube pre? Then add the color to any good mic?
t
t
FET's add odd order harmonics, which sound bad.
Unless you use a really expensive FET it will never "breathe" the way a tube does.
This is not correct. It's more the topology of the circuit that affects the spectrum of distortion. Also, might be worth noticing that many think that analog tape sounds good, but it does produce lots of odd order harmonics.
Nonsense. The price of the FET has nothing to do with this. A FET is a very inexpensive device to begin with.
Martin
FET field effect transistor, lot's of different types mosfet blah blah blah. Not interesting.It's a transistor, the descreet equivelent to a tube.
There are more even harmonics than odd harmonics with analogue the opposite is true for digital.
The only reason digital is around is that it's cheaper, more reliable & easier to work with, live with it
Relax _brian_, we're here to share information. Let people contribute.
Martin,
Are you offering Google & wiki as sources of accurate info?
Pulling someone up on an error is fine BUT please try to do it in the sense of a discussion rather than an argument or browbeating.
You seem to have a lot to offer - if you'd like people to pay attention please skip the bitter pill policy and opt for brevity and wit.
As an example I'm with you that tubes usually "behave better" when driven into clipping, any guitar player knows that. But in my experience, microphones are not normally operated at such high SPL's
