Why Room Treatment Matters - Audio Sample
  • Thread starter Thread starter KineticSound
KineticSound
KineticSound
The VOICE
I just completed my new studio build about a week ago (pictures in another thread) and thought I would post a short sample of a little experiment that I did before and after construction.
First off, a disclaimer: The audio sample posted here is not intended as any sort of "final mix", rather it is simply a rough cut of drum tracks intended to highlight the difference between tracking in a concrete basement with little treatment vs. tracking in a fully constructed, treated tracking room. The performance is sloppy at best. ;)
The test was conducted with the exact same mic's in the exact same placements using the Glyn John's technique... Two Shure SM57's (one for kick and one for snare) and a pair of Shure KSM32's as overheads.
These were recorded over a couple of MIDI backing tracks (What You Won't Do for Love), but I left only the Rhodes and Bass tracks so you can hear the difference in the drum tracks.
For the new kids, this is why room treatment matters. You can easily tell how the sound of the kit dramatically tightens up when tracked in a proper room...
Put up the before treatment clips if you have them....that way there is a reference point.
They are there...
I should have pointed out that the drums fade from untreated -> treated -> untreated -> treated. About 10 seconds or so of each.
Very nice example of the benefit of room treatment. Thanks for posting.
This should be a sticky thread.
They are there...
Oh...I see.... I thought it was just a clip after treatment.
Well...I can hear the differences, though honestly it's not coming across as very dramatic in that clip.
Basically...it goes from a little more room to a little less room on the snare...with the kick rather subdued either way.
Maybe if you just played the drums without the MIDI tracks, and then run through the whole kit rather than just the snare/kick.
Clip won't play - some prob at soundclick - error message after i tried the link.
