M
malamatata
Hi guys,
I was wondering if you guys could help me with this problem. My ableton always recording two notes when i am using my Alesis QX49, but when i using my keyboard OR drum pad on my midi, it seems only recorded one notes.
You could check on it here (because somehow, i cannot post any links before post it several times ?) ==> www(dot)youtu(dot)be(slash)Zb71AHKTejA
Its been going on a while now, I already tried to update my driver, check on my midi input on ableton, reinstall the ableton, but none of the options seems to worked. if you guys could help me with this issue, i would really grateful.
Good day for you all !
[SOLVED]
As Rob Aylestone suggested, I changed my midi out from USB KEYBOARD to USB, and voila, its solved !
To solve this, press advanced, and press midi out until the indicator that says "USB Keyboard" changed into "USB" and then press advance again
[SOLVED]
