I cant even get Fade To Black to play.
Testosterone sounds muffled and buried, like its under water. Why did you start out with eq'ing it? I'm sorry I dont know what to suggest, without seeing what you are doing.
The most obvious thing is that Logitech USB Mic is a $15 dollar mic intended for karaoke and games. If you are recording direct into your pc, then you may have issues with gain stages or input levels. Remove all the fx and just see if you can get a good hot clean mix using straight guitars and other insturments without the fx...... mix the drums first, then the bass, then one rhythm guitar. Get it to where it sounds like a 3-piece band practicing. Then add in your leads and solos.
Great guitar playing on Burn......good mix on Bloodshed......what did they do different??
