for the soundcard the patchbay/router choices are the following:
wav out 1/2,monitor mixer,s/pdif in,s/pdif in (l/r rev) and h/w in 1/2.
im going ANALOG so these are the remaing choices wavout,monitor mix and hw in 1/2
i checked WAV OUT 1/2 and recorded a piano on CW. i tried to record bass next. i couldnt even hear the bass sounds coming out as i played. however it did record but i heard the bass and the piano on the same track when i played back.
now i checked monitor mix. recorded a piano. heard it while i was playing it and when i played it back. recorded another bass sound. both the piano and bass were on the same track.
now i checked h/w in 1/2 i can hear it before and during recording. when i play back no sound comes out. i have to switch back to wav out or monitor mixer to hear it and guess what? same thing. piano on one track and piano and bass on another track.
so i DOUBT very seriously that it is sound card configuration. must be within cw.
i have loop recording to store takes on seperate tracks.recording mode is set to over write. how do i turn off the CLONE settings? this is where i think the problem lies.
here is an excerpt from the cw help menu.
Track/Clone
This command copies a track with either its properties, its clips and events, or both. You can specify a destination.
See also:
Copying Tracks
now here is what cakewalk says when i click "COPYING TRACKS"
Copying Tracks
When you copy a track using the Track-Clone command, you can choose to copy the track properties, the clips and events in the track, or both. You can also choose the destination track. By default, Cakewalk copies the entire track to the next open track.
so i went to clone and i uncheck events and properties and i press ok. guess what? they are checked when i open the screen again. so i decided to choose the same destination tracks. same problem. it seems that the ONLY way this doesnt happen is if i MUTE the previous track. however how will i be able to know whats going on if i cant hear it? this SUX
czar
