Steenamaroo
Hi all,
You may remember I recently asked about a Kawai DX900 organ with a bunch of missing notes?
Well, I sourced and replaced a few of the divider chips and have restored this thing to full functionality.
The only real problem is there's a bit too much noise for recording, so I was hoping some of you might be able to help?
There's two different noise issues.
1:
Some background interference. Reasonably high pitched erratic whine - sort of like you'd hear with cheap PC speakers and onboard audio.
You can hear changes in the whine when changing certain settings, flicking switches etc.
The organ has a built in rhythm pattern section with variable tempo and I can hear a faint pulse/click which coincides with the tempo L.E.D.
This interference does get louder/quieter with master volume/expression changes, and is present on the headphone output.
2:
A mild mains buzz/hum.
This organ originally had a huge mains hum caused by a -15v rail which was running at about -22v. I believe this was also what blew the divider chips.
Upon recapping and repairing the PSU, the hum was fixed.
This mild hum appeared one day after fitting the new divider chips. At that stage the organ was already reassembled and hadn't been moved since, so I'm at a bit of a loss.
I have re-checked PSU voltages for safety and everything checks out.
This buzz does not get louder/quieter with master volume/expression changes, and is not present on the headphone output.
So, I guess I'm dealing with a weak/damaged ground connection somewhere...
Where to start?
The full service manual is pretty low quality, but is available here......
http://www.steenaudio.com/shared/dx900.pdf
Audio examples of both interference and hum are available here.....
(Organ minimum volume)
(Organ maximum volume - static clicks towards the endare me selecting different voices)
There's nothing nearby to interfere...tube lighting, transformers, amplifiers etc..
Many thanks in advance for any suggestions or info.
1:
2:
Where to start?
