D
Dannyvocal
I got a Yamaha Multitrack Cassette Recorder MT4X. I am wondering if it is working. If anyone understands its operation, could you verify that I understood the manual properly for the simply task of recording on Tracks 1, 2, 3, or 4. I am succeeding in recording on Track 1 but not Track 2. According to the manual, if I record on Track 1 I must push the Assign 1-2 button down and turn my Pan hard left (what if I don't?). To record on Track 2 I push the Assign 1-2 button down and turn my Pan hard right. My Tape/Mic button is OUT if I want to record. The only thing I must do (other than hit the Record and Play buttons) is hit the Rec Select buttons for Track 1 or 2 depending on which I want to record on. Does that sound right to you? To play back it shouldn't matter what my Master buttons are doing (they too require assigning, still not sure when I tackle those). It also shouldn't matter whether I select the Group, Stereo or Cue Monitor Select buttons - at least, not when it comes to only hearing Track 1 and not Track 2. Obviously to reach each track I am plugging my source directly into the Input 1 or 2 in the back for the right channel. But when I record track 1 I see the volume fluttering in the Track 1 LED column, but not in Track 2 when I record on Track 2 (even though I do see it fluttering in the Stereo columns). I am puzzled and frustrated. I am wondering whether I bought a model that does not work. What say you?
