Which Would You Choose????????
  • Thread starter Thread starter shAkEz_gk
shAkEz_gk
Now, This is my 2 choices.
This will be for recording VOCALS only, one track at a time!
Echo Mona $679.00
4 universal analog inputs with 110dB (A-weighted) dynamic range
6 analog outputs (both XLR & RCA) with 115dB (A-weighted) dynamic range
24 bit optical and coaxial S/PDIF digital I/O
ADAT optical digital I/O
Headphone output with volume control
Word clock I/O
Rack mountable single space breakout box
15’ cable to connect to PC
4 high quality mic preamps with phantom power(+48v)
Trim control and level meter for each input
128x oversampling analog-to-digital converters
Full Duplex 12 channel in 14 channel out operation.
PCI or CardBus bus mastering interface
+4dBu or -10dBv analog I/O on each analog channel
Software Features
Word clock I/O
Software console for monitoring, metering, and setting levels
Driver support for Windows 95/98/Me/2000/XP and Macintosh OS 8/9/X
Support for WDM, ASIO and GSIF
Low-latency drivers
Compatible with all popular recording products
Built-in digital mixer provides near-zero latency monitoring
Wami Rack 192X $579.00
WaMi Rack 192X Technical specifications
High quality 24bit 192kHz AD converter; 123dB Dynamic range
High quality 24bit 192kHz DA converter; 106dB Dynamic range
4 Channel Analog Inputs:
4 Balanced +4dBu Line inputs (1/4" TRS Phone)
4 Balanced adjustable Line/Mic inputs (XLR Connector)
8 Channel Analog Outputs:
8 Balanced +4dBu Line Outputs (1/4" TRS Phone)
2 Balanced +4dBu Line Outputs (XLR Connector)
4 channel MIC Preamp with +48v Phantom power
1 Headphone Preamp
S/PDIF Coaxial Digital In/Out: up to 24 bit 192kz resolution
Supports multiple Sampling Rates : 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
Full Duplex - Simultaneous Record/Playback
Uses 32bit PCI slot: PCI Bus-Mastering support
1 In / 1 Out, 16 channel MIDI Interface
Supports the EWDM driver:
Multile MME, Multiple Direct sound, ASIO 2.0 and GigaStudio support
OS: Microsoft Windows XP/2000/ME/98SE
WHICH WOULD YOU CHOOSE?
Neither. Both are overkill for recording vocals one track at a time. Get a small preamp and an Audiophile card and you'll spend half the money and have all the features you need. There are many other choices too that have one or two preamps built in that are well below the cost of either of these units.
