which pickup?
  • Thread starter Thread starter sathyan
sathyan
Not sure if this is the right forum ...
What pickup would you recommend for a violin?
I want to run this signal through a guitar effects pedal (Zoom 505 Guitar).
Signal chain will be:
Violin
Pickup
Zoom Pedal
Crate Amp
SM57
Mixer
A/D
Soundcard
I want it to be easily removable so that it won't affect my microphone (SP B1) recordings of the acoustic sound.
Sathyan
Fishman makes a fine violin pickup, and though it is not easily removable, it has no effect on the acoustic sound of the instrument. This is the industry standard aproach to amplifiing the violin in live settings.
FISHMAN'S WEBSITE
Light
"Cowards can never be moral."
M.K. Gandhi
Outlaws said:
They make pickups for violins now you know.
There are some pickups for acoustic guitar that start at $30 (Duncan) and $40 ( Dean Markley) whereas violin pickups are over $100 for Fishman or LR Baggs (Alison Krauss uses the latter). Will a guitar pickup work on a violin?
The other reason I'd like removable is to try it on my mandolin as well.
Are preamps needed with a pickup or can it be taken straight to a pedal/amp/DI?
thanks
The guitar pickups will not work on violin, as the violin has an extreme arch to the fingerboard, so the level between the strings would be off, as they are magnetic pickups. Those pickups suck, though, so you are not missing anything.
If you really want something you can move between your violin and mando, you could use something like THIS, but I don't recommend this, as they can not be put in the place on the instrument (either one) which will sound best. In a live situation, they are also more prone to feedback.
Fishman (and Baggs too, I am sure) also makes a mando pickup, if you need one for the mando.
All piezo pickups require a preamp of some sort to sound their best. Some models, particularly for guitar, have built in preamps, such as the Highlander (which was the first), the Fishman Matrix, or the D-Tar Timbreline. I have not noticed any of these for the violin or mando, however, so you would need some kind of an external preamp, as the output of piezo pickups is millions of ohms, and guitar amps and mic pres and such are looking for a signal in the thousands of ohms. Using a pickup without a preamp will lead to a very tinny, brittle sound, which is very unpleasant. You could, however, use the same preamp for both the violin and mando, though I would suggest getting different pickups.
The other possibility, if this is only for recording, is running the effects processor from either an aux send (preferable, for me), or as an insert on the channel. This way, you get the sonic advantages of the mic, and if you use an aux send you can mix the dry signal with the effected signal to best effect.
By way of full disclosure, I deal both Fishman and Baggs products (though I sell far more Fishmans than Baggs).
Light
M.K. Gandhi
