Which mixer?
  • Thread starter Thread starter okole_puka
O
okole_puka
Hi all-
I'm new to this board. Been reading quite a bit and have learned a lot. I know this has probably come up, I did try searching but couldn't find exactly what I'm looking for, so here goes.
I'm trying to set up a home studio and I'm trying to decide on a mixing console. I've narrowed it down to these three:
Carvin C1644
Mackie 1642 VLZ Pro
Behringer Eurodesk MX2442A
I'm planning on recording to a computer via a M-Audio Delta 44.
Any thoughts, suggestions, other consoles to consider?
Price, as always, is a factor. As well as quality and ease of use. I'm kinda new to this but a (hopefully) quick learner. :D
Also, I'm looking for active nearfield monitors. I see alot of people like the Wharfedale's. Anybody tried the Carvin SRS 6.5A?
Thanks-
OP
Hi Manning1-
Thanks for the quick reply. I'll look into the Yamaha's. (Do they have 4 bus outs?) And I'll check out the websites.
I'm actually going to be recording guitar tracks. Not going to be using MIDI too often.
As far as the PC, it's a P4 2.8 Northwood w/ 512 mb, M-Audio Delta 44 PCI interface. Haven't decided on software yet. Looking for something cheap and easy. (Coincidentally, attributes I look for in women. j/k ;) )
Thanks again-
OP
P.S. Keep the suggestions coming. I have a feeling I'm not confused enough yet. :D
your system is great. to go into the delta 44 inputs you go out the channel insert on the mg.
you wont beat the multitrack software i use even if you spend loads of money. heres the link. note..try the demo. youll be amazed . even does vocal pitch correction and harmonisation. 48 tracks audio or midi or both. if you dont believe me talk to folks on the forums at pg.
http://pgmusic.com/powertracks.htm
nothing comes close.
you should look into the Yamaha 01V series although expensive it is a nice digital board and will not fail on you like mackie or behringer might.
