B
BAMA
just was wondering does the sound quality change?
What Benny said is good advice, however, depending on what Pro Tools system you are working on I would start each session at the highest resolution possible. For instance, if you are working on PT HD, start at 96kHz, and bounce to 44.1 or 48.
What works out really well when bouncing is to bounce straight to a CD using a CD-R machine, that way you don't get digital rounding errors when bouncing your file to a .wav.
Hope this helps!
Isn't there a theory about sample rate conversion?
Like, if you're destination is 44.1 and you want to track and mix at a higher
sample rate, you should use 88.2? (88.2 divided by 2 = 44.1). Same applies
for 96kHz and 48kHz?
I'm not sure![]()
