Which brand is the best mixer?
  • Thread starter Thread starter subpop
subpop
Hello I'm new to here and new to be a vocalist. recently my mixer was broken. the problem is that when I try to turn up the volume. it makes noice called feedback? sound like keeeeeen--- it makes me headeche. so I always have to turn down the volume this makes more problems cause I can not hear my vocal clearly. so I was wondering which brand's mixer is the best? and makes loud sound without keeeeeeen sound? since my band is screamo it's important to make loud sound. Thanx
buy equalizer and hire soundman to remove keeeeeeeeeen. that would be best mixer and make loud better.
If it is truly a feedback problem, then it could mean that you rmixer is not broken, just set up wrong. Feedback occurs when a signal is fed back into itself. You can easily route things incorrectly and get feedback.
Check the signal routing on your mixer and make sur ethat you haven't fed the signal back into itself at some point. The first way to check this is to turn down all the channels and sends to zero, and then turn up your one channel and see if there is still feedback.
Can you tell us more about how you've routed the mic through your mixer?
