dobro
Okay, ready to do some more work on the studio (as opposed to *in* the studio).
In another thread, Knightfly said this about fibreglass placement on the ceiling:
"Unless your ceiling is already absorbent, you need to eliminate early reflections between speakers and ceiling - you do this by putting up a "cloud" whose front-to-back center is halfway between you and your speakers, and center it left-to-right. Typically this needs to be at least 4 x 6 feet to catch any possible reflections."
Well, that's advice I'm going to take, but the question I've got is where to put the monitors and myself. I know about the equilateral triangle idea, but where to put that triangle in a room like mine? How much does it matter? My room's got these dimensions:
14' 4" long
9' 8" wide
11' high
The attached diagram will give you an idea of where things are in the room. In addition to what I've included in the diagram, there are also 8' rugs hanging from all the ceilings, which do a nice job of killing echo. The floor is lino on concrete, and I've got a carpet on it. The walls are plaster on edcon blocks, and the ceiling's about nine hard, thin panels of some sort of material, above which is a big attic.
With that kind of room with those dimensions, where should I sit? What about the monitors?
14' 4" long
9' 8" wide
11' high
