ManInMotion711
When EQing bass into a mix, where should it sit? Iv'e heard boosting the EQ around 250-500 is a good spot, is this reliable information? Iv'e been told this by 3 people, im just curious what works for other people
Where should the bass sit
Right outside the studio till everything is done.![]()
And/or 120-400 that mud and boxy' tone area tracks tend to pile up in.Here is the way I think about it:
50Hz: sub frequencies to make it sound deep
80-120Hz: solid, classic low end
250-400Hz: low mid growl
700-1khz: articulation...
For this question, I can't get beyondWhere should the bass sit ?
andIt depends on the style of music and dialing it in right from the get-go. There simply are no rules. Different mixes require different bass tones and different ways to "sit" in the mix. Some people swear by stuff like "I gotta notch out this to make room for this and boost this and then notch this". Totally unnecessary if you track the right kinds of sounds to begin with. So basically what I'm saying is to use an appropriate sound to begin with. And if you don't, then you do whatever you need to do to make what you have work. No one can tell you to boost or cut in any frequency range without hearing it first.
Personally, I'm hopeless when it comes to Hz, KHz, mids and all the rest. I know what the dials do to the bass by tweaking them and listening. Ultimately, you'll either like the sound or you won't.Forget everything you've been told about EQing and processing to get the bass to "sit right". It's impossible to give you balancing and processing advice without hearing the bass in the context of the mix. This is best captured at the source but there's nothing wrong with adding a bit of bite or a bit more lower mid, providing the mix won't suffer.
You may have a point there. While a well played bass ought to be fairly level in tone at least, on some of our stand up bass tracks I'd been chasing with narrow eq's to even them out.You should definitly look at the dynamics before EQ, try running it through a limiter pretty heavily, see if sits better, once you get there ease up on the limiter until it sounds normal.
