Where is: "Transmit" for the Roland GI-20 GK-MIDI INTERFACE
  • Thread starter Thread starter MrMusicAu
M
MrMusicAu
Using the Roland GI-20 Midi Interface hooked up to my PC via USB, Where is the Transmit?
In the manual it tells you how to load patches from the PC to the Unit. Below are the steps and question I have on transmit:
MANUAL STEP BY STEP INSTRUCTIONS:
Recieve Saved Data Through USB (BULK LOAD (USB))
1. Use a USB cable to connect the computer and the GI-20.
2. Start up the application on your computer that will be handling the bulk data.
3. Turn the PARAMETER Knob to "BULK."
4. Press [SELECT] to select "Lu" (LOAD (USB)).
5. Transmit the data from the computer.
6. When finished turn the PARAMETER knob to "PLAY MODE".
Here's my question again:
Where the heck is the Transmit if not on the Roland GI-20?
Any help would be very much appriciated.
Andrew.
