E
electricabanana
Hi.
i have recently realized i was recording too hot, and now record at what seems to be the generally accepted level (around -21 or -18). obviously, this is quieter than i am going to want for the finished product (i think final mixzes should peak close to 0db, n'est-ce pas?).....by the way all the level numbers i am refering to are the scale that is used on the computer side of things, as opposed to the mixers and preamps i'm using.
my question is, at what stage in editing do i make it louder. should i mix the (quiet) tracks in cubase-->then mixdown-->then normalize the mixdown. or alternately, normalize each individual track before mixing so that the mixdown is at a reasonable level. does it make a difference?
also, i dont think i fully understand what mastering is (as seperate from mixing). i have a loose sense that it involves doubling tracks to increase volume or something...i think i've also heard of using tube preamps for mastering...????....can anyone point a newbie to a good mastering basics resource (i tried searching, but it yielded too many specific results, nothing general...).
thanks in advance for sharing your wisdom!
