What's wrong in this? suggestions
  • Thread starter Thread starter ZoelVazra
You have some build up in the bass/low mids. I'd cut that from the vocals. Give the guitar the low end and let the vocals have the middle and some high end. The guitar is too effected IMO, but that might be what you're going for.
Run a tight Q EQ boost across those vocal tracks and find that anoying freq and then cut it, I'm guessing around 600-1200Hz. Also there's distortion in the vocals in spots. Make one of your vocal doubles a background vocal and pull it down and give it some funky eq treatment then blend it back in.
Smaller reverb and put some on the guitar, then add some air to the vocals...a little high shelf should do it, probably need a de esser after after you do that.
Also put soundcloud in square brackets followed buy /soundcloud in square brackets around your soundlink link to make it clickable in the forum like this
