T
Tabnak
Member
Under the pulldown-menu -Options -Audio, under the general tab, you can specify the 'audio driver bit depth' and the 'file bit depth'. Does anyone know the difference between these two?
When I plan to record something new, I usually set the sampling rate to 48,000 Hz and the file bit depth to 24 bit (the higher, the better, is it not?). But when I set the audio driver bit depth to anything other than 16 bit, my soundcard (SBlivePlatinum) doesn't support it. That's ok by me, but then I still don't know what that is. Anyone?
