billbone said:
with all this being said, today's test/observation probably makes sense:
I attached a TS 1/4" adapter to my mic's XLR plug, and plugged it into my PA. Sure enough, the volume dropped a bit more than when I plugged the XLR directly in!
So the solution here would be to go buy a TSR adapter for my XLR plug. The volume should be better. Right?
not necessarily. I think daav confused you with that post by Harvey. And although I understand what Harvey is saying, I don't think the multiple balanced-->unbalanced conversions are nearly something to worry about as much as multiple A/D/A conversions are.
Like I said, you need to know what you're plugging into what.
What kind of microphone are you using? Where are you plugging it into on the mixer? Remember, this is electricity we're talking about and you have to put electricity into it's appropriate places.
Probably what is happening in your case is the microphone is a Lo-Z (low impedance) microphone and it HAS to plug into the XLR. The reason being is microphones put off a very low voltage signal that has to be amplified. And in a mixer, after the XLR points, is a preamplifier that amplifies this low level signal up to line level. If you were putting the adapter on the XLR and then plugging it into the 1/4" input on the mixer...then you are bypassing the preamp and in effect telling the mixer that it's a line level device...which it's not.
A good general rule of thumb...mics get plugged into microphone inputs (ie. XLR inputs)
Line level devices like a tape player, outboard gear, and sometimes guitars get plugged into the 1/4" inputs.
The microphone was built with an XLR output on it for a reason. Match that XLR with an XLR input.
Now if your microphone states on it that it's a HI-Z microphone, that's another case...but let us know what microphone you're using first and what mixer.
