Chris Jahn said:
that makes sense, its a decent aproach and kinda the one i had in mind, basically improve your "input" and work toward the end from there.
Yep. The key is to frontload the quality. This starts with the performance itself. A great performance will by it's nature sound better than an average one, regardless of the gear quality. Then get the tracking down. Without good tracking, the rest won't matter, with good tracking the rest can (almost) take care of itself. And so on.
Which is why I recommended the pres over the summing box (the only two choices you gave at the outset
. But yeah, if we were to expand past those two choices (and hiring a roomful of Nashville Cats to play for you isn't an option
), microphones would be at the head of the signal chain and would be #1 to look at.
Chris Jahn said:
On a specific note, the two chanels like the rosetta, this is a two channel interface im assuming (i guess ill just look it up) but why jsut the two, why not an interface with more inputs
Fine, if you can afford it. But remember what Al said about a grand a channel?
The UA 2192 that he uses is around $2400 for two channels new,
the Rosetta 200 about $1800. And that just for the converters, that not including mic pres like you Firepods are. There is a Rosetta 800 that gives you 8 channelss for about $2700, but it's still a lot more expensive than what you're used to.
Chris Jahn said:
And also, is the stuff i have really that bad? I tried to make some decent descisions up front with some good research, and droped about 8 to $9000 by the time i had every last boom stand, mic clip and pop filter. Just to have what i do have, and now i feel like i wasted that cash on "prosumer" junk.
No, it's not that "bad". There no reason why cou can't get perfectly listenable results from it. But there is a lot of upgrade room.
It's like asking if a Canon EOS Rebel camera is "bad". No it's not. Would Ansel Adams or Annie Leibowitz use one? Nope. Not on a cold day in hell. Could you (with the proper lenses, lighting, etc. etc.) take perfectly good quality pictures with it? Sure. But they won't be Ansel Adams or Annie Leibowitz like.
There is a LOT of room for upgrade hardware wise. But the thing to remember is that the gear won't do it for you. You could have a top-of-the-line Hasselblad camera, but if you don't know lighting, framing, exposure, etc., your pictures won't be any more worth looking at than ones taken with a plastic disposable 35mm from your local CVS pharmacy's checkout line. No offense intended, but be honest; if someone stuck you in front of a big coal-burning SSL console with a mic locker the size of Keith Richard's medicine chest, would you really know what to do to make great sounds? Not yet.
If you got the money to burn, go ahead and get a decent mic and mic pre and I can guarantee you'll hear at least some difference off the bat from what you got now. But I think the absoluet best investment you can make is in time and expeience itself. When you get to the point where your gear is actually holding you back, the the upgrade will really be worth it.
G.
