capnkid
Optimus Prime
Nobody around here sells it. I can't just use aluminum foil can I?
Sure you can. There's shielding paint as well.
I thought there was lead in the tape or something special.
Go to a hardware store and pick up some foil duct tape. It us used for heating and AC ducts.
how does the ground work then? A new jack with a ground wire?
Daav
You should be able to get copper foil tape at any decent hardware store that sells garden supplies. It's sold as a way to keep slugs out of your garden. Copper tape works much better than aluminum. The thickness matters, as does the conductivity. You want the thickest stuff you can get, and the stuff people use in gardens definitely qualifies. It's really heavy stuff.
The slug copper tape glue (at least on the stuff I bought) has thin enough glue to make a solid connection through it (unlike the shitty copper trace tape I bought at Fry's which NEEDS to be conductive through the glue!) so you pretty much just apply the stuff and make sure it makes physical contact with the foil that's already on the back of your guitar's faceplate.
have you directly compared heavy duty aluminum foil and copper foil tape in the same guitar?
The slug copper tape glue (at least on the stuff I bought) has thin enough glue to make a solid connection through it (unlike the shitty copper trace tape I bought at Fry's which NEEDS to be conductive through the glue!) ...
