The example in the 388 manual for A/V shows the 388 connected, via an unnamed synchroniser, to both a C-format 1" VTR and a 3/4" U-matic VCR. Since both systems appear to be tape based would it be reasonable to assume that anything that can be used to transmit timecode from a VTR or U-matic could also be used to transmit timecode from an audio tape machine? or would such a device have to have been made specifically to sync two audio tape decks together?
I’m not totally sure I understand your question and it’s just semantics…not sure what you mean by “transmit time code”…VTRs have audio tracks. Some VTR formats have dedicated time code tracks as well. So time code is striped to whatever appropriate track on the VTR and then the output jack of that track is connected to the time code in jack for that machine on the synchronizer. VTRs, as you said, are tape-based and have tape transports like an analog audio tape machine, so VTRs, given they have the functionality, can interface a synchronizer just the same as your 388, for instance, and either be slave or master or code-only master in a sync array.
I expect it goes without saying that an MTS-30 (or even 1000) wouldn't cut the mustard.
The MTS-30 doesn’t do machine control. It is a MIDI tape synchronizer. It takes time code striped to your tape machine and converts that to MTC for triggering actions and events and such on your MIDI device, like a sampler or sequencer or whatever. It doesn’t have any ability to control a tape transport. It only allows you to slave a MIDI device to time code on the tape machine.
The MTS-1000 however does the MIDI thing but can also interface two tape transports and either set them up in chase-lock or slave them to incoming MTC. The Micro Lynx does this also, but can also, depending on the options installed, control three machines, and interface other protocols.
I don't think we could sync all three machines.
You can if you have the right synchronizer. As I mentioned in my last post the TimeLine Micro Lynx can do this, if the third machine option card is installed.
The 80-8 only has the one tape speed and I suspect that trying to sync a machine running at 15 IPS with one running at 7.5 would be a nightmare (the Otari does 15 and 7.5).
Wait…where did the 80-8 come from? You said there was an Otari 5050-8, and two 388s…?
Tape speed has nothing to do with sync as far as what the machines in the sync array are running. If you record time code from a time code generator simultaneously to a tape machine running at 7.5ips, and another running at 15ips, and then reproduce the time code from each at the same respective transport speeds, the time code will reproduce the same from both. If you switch the 15ips machine to 7.5ips after striping the time code, now it’s not going to work. Set the transport speeds where definable to the speed that best suits the projects as far as the audio tracks. Stripe time code. Lock them up and start tracking.
